I have to tear the heads off of the engine, so I figure while I'm at it, why not just put a cam in the car. The problem I have is I want to find a cam thats gonna give me a decent power gain, but not piss off the computer really bad. The car already idles at about 950rpm +/- 100rpm at idle, so the computer shouldn't have a problem there (the car has a chip which raised the idle). I just don't want it to not know what to do about fuel and all that. I found the cam I would use if it was an N/A engine, which is the Comp Cams 260H (i think thats what its called). The problem is that its a turbo engine, and I don't know how well that would work. It should work better than the stock cam because it does have significantly more exhaust lift and duration but I'm not really sure. And basically I'm just looking for a gain over stock, whether it be 5 or 50hp, a gain is a gain.
If anyone has any ideas of a computer friendly camshaft that would work well in a turbo engine, thats what i'm looking for. If you don't think the cam I am looking at would work very well let me know.
Also, what should I do for lifters, pushrods, and valvesprings? I plan on spinning the engine to about 6200 on shifts with a limiter at about 6600, so I want the valvetrain to hold up.
I'm open for all suggestions. I wanna get this figured out soon, because I want to be able to buy the parts and tear this thing apart sometime in the next 2-3 weeks.
Thanks,
Shawn
Thanks,
Shawn
