LX9 swapped Grand Prix, 5 spd. OBD I ecm.
When the motor was on the stand I replaced the LIM gaskets. When it was in the car and started up, a pushrod slipped off a rocker arm on #4 intake valve - essentially causing it to run on 5 cylinders. Before I discovered the issue to the poor running motor I had to have it emissions tested. The car exceeded the NOX limit (with a brand new 3 way cat) by a few hundred parts per million over the threshold.
Now, after discovering the 'missing' pushrod and correcting the issue the engine runs incredibly well - though it still needs some ECM tuning.
Lets assume that the tune was spot on, should I be able to pass the NOX test without an EGR? How about without an EGR AND lean cruise enabled in the ecm?
My dilemma is that during my swap I decided I didn't need the egr and I welded closed the bung on the exhaust manifold. If I need an egr I believe the approach I will take is to weld a bung into the downpipe and run 3/8" brake tubing to the egr valve. Will the 3/8" tubing be sufficiently large enough for proper egr functionality?
That said - the old dohc motor passed emissions on a 2 way cat, with retarded exhaust cams (lope), no egr at all and lean cruise enabled. So I'm hoping a bone stock LX9 can do it, but I think I may just add the EGR and be 100% in compliance and not risk another failure.
