96 Grand Prix 3100 SFI
Getrag-282 from a 1989 McLaren Turbo
Bell housing is W-Body swapped during the rebuild. But came from another donor of another make/model. Getrag was built by Pontiac Jeff from Engineering Performance in Florida.
The Hydraulic throwout bearing fits a 1993 Cavalier 5-Speed (among others I'm sure).
Are there any dimensional differences requiring the HTOB to be shimmed? And if so, how much?
Because I am using a new clutch system, new master-lines-slave. But I can not get the clutch to disengage the trans. And I bleed the f**k out of those lines. Pushed fluid up from the bottom bleeder until no bubbles, then bleed back down using a check valve to prevent air going back up. I seriously doubt the issue is air in the system.
The clutch pedal has excellent travel length, starting 1" ahead of the brake pedal rested and goes to the steel frame. It has a pressure kick back so the pedal doesn't just rest.
This is crazy frustration. I think I might need to pull the engine-block again just to measure the distances.
