abs help
  • abs help
    So recently I have been upgradeing my subwoofer system... I started my car and drove to wal-mart, (its the only place close that I could run my system hard) 14miles away. I got there parked, n left the car running while I tuned my amp. Now once I was done I got bk in the driver seat and my ABS light was on... I had been up front a few times n it wasn't on... I turned off the car turned it bk on n the light was out... I was about 2-3 miles from home and it came bk on. What could cause this? As now its on no matter what
    1995 cutlass ciera
    1995 Ram Air V6
    Low system voltage can cause it. Most likely you have a large amp or your alternator is starting to get weak or go out (or both). A capacitor for your amp wouldn't be a bad idea if you can get the ABS light to pop on.
      Hum I'm olny running my amp at 1/4th volume, my lights don't even flicker, the ABS light dose when my bass hits hard, guess ill need t get a 220amp although from DC or powermax
      1995 Ram Air V6
        I wouldn't exactly spring for a huge alternator just yet. How big is your amp?
          4000w amp, pushing two Rockford fosgate p3's,
          1995 Ram Air V6
            Light went off after being on for 3mins today... im so stumped.
            1995 Ram Air V6
              4k watts? Never mind, get that big alternator, lol. And a second battery for the trunk, preferably and Optima. I would do an Optima up front as well, along with a large capacitor.
                Lol. N I'm only at 1/4th volume on the amp n it takes dumps
                1995 Ram Air V6
                  It's taking dumps because it's not getting enough current. I'm willing to bet your current alternator isn't up to snuff. If I were you, I would go to the nearest parts store that does free charging system testing and have both the battery and the alternator load tested. If the battery is bad, replace it with an Optima. They may be expensive, but they are awesome batteries.
                    Takeing dumps as in so loud you don't wana stay in the car
                    1995 Ram Air V6
                      taking dumps as its the alternator not able to keep up with the power draw form the amp...... its the alternator sorry but it is .... either get an alternator or a cap or both
                        Have you retrieved the ABS trouble code? Even after the light goes out, it should be retained in memory.
                          How id have to go to a shop n around here they are thrives, tryed to xharge me 800$ to do my water pump as one place 700 at another...
                          And if its my alt, then y dont my lights flicker... ever? They don't dim, dull, or pulse, doors open n highbeems on?
                          And I noticed while driveing if my LOW TRACTION light came on while breaking then my ABS light would kick on n id lose a half inch of break pedal
                          1995 Ram Air V6
                            Check this out, see if it helps. Sorry to hear about the shop rates in your area, but with some diligent research you should be able to do this.
                              Ah, ok. When I read dumps when talking about car audio, I assumed the sub amp was shutting down for a second from not getting enough power.
