Need Help: Where Does This Go?
Originally posted by HOYS View PostHard to see but looks like an O2 sensor plug.
Got it done and then started it and now got this tick. anybody know what it might be and how to make it go away
Are you 100% certain you kept the pushrods in the right order? That sounds a little extreme to say let it run a while to let lifters pump up.-60v6's 2nd Jon M.
Originally posted by Luang View PostThanks i did it and it worked
Last problem is that now the idle while in park is around 2300 rpm and in drive around 1200. Any ideas?-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostCheck for a vacuum leak. I tend to forget the brake booster hose on those stupid vans since the bay is so squished and it's clear in the back, then wonder what in the world is up with the idle...
Maybe check your throttle cable then. It could be hung up on something, or check the cruise module and linkage hookups on the TB itself for binding and possibly causing the TB plate to be stuck partially open.-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostMaybe check your throttle cable then. It could be hung up on something, or check the cruise module and linkage hookups on the TB itself for binding and possibly causing the TB plate to be stuck partially open.
Disconnect the TPS and see if the idle is fixed. Or if you have something that can show you the throttle percent, i.e. a scanner of some sort, check to see what it is. Should be zero at idle.
Disconnecting the TPS will throw a code for low TPS voltage, but the computer will report the throttle position at zero.
Idle relearn?sigpic"It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
