just replaced the head gaskets on my moms van (03 Chevrolet venture). the gaskets were fine, but one of the rocker arm threads on cyl. no 5 stripped out. i couldn't fit my drill back there, so i pulled the head to helicoil it. while i was at it i pulled the front head and replaced both gaskets (new intake gaskets and all that jazz). i have everything back together, now its running like crap and it is loud - sounds like the top end. it almost sounds like it did with the stripped rocker arm thread, but louder. when i first started it i thought maybe the lifters just had to pump up, but its definitely missfiring. i thought maybe one of the rocker threads pulled out again, so i pulled both valve covers - all of the rockers are tight and on their pushrods. i turned the motor over by hand. all of the pushrods and rockers seem to be working. i had the pushrods organized when i took it apart because i know intake and exhaust are different sizes, so i dont think there is anyway i could have mixed them up. i checked the oil - there is no coolant in the oil.
i hooked the scanner up to it and im getting a p0300 random missfire code. i double checked to make sure all my wires were in the right place and that checked out.
not really sure where to turn - i guess do a compression test on the cylinders to see if i have compression in all cylinders?
has anyone had an issue like this before?
