I concur with Brad, and I was thinking the UIM that wasn't red and black was not painted. Doh! Yeah, don't do brake clean on paint.
#3 Misfire after LIM Change
Good stuff! I'd like to do a quick and nice write up about replacing LIMG's including using the rocker arm pry bar, but i'll have to wait till i have to do one of those jobs to take pictures.
Bob
Originally posted by bob442 View PostGood stuff! I'd like to do a quick and nice write up about replacing LIMG's including using the rocker arm pry bar, but i'll have to wait till i have to do one of those jobs to take pictures.
Bob
Great Item! I might have avoided this if I had one. But its all for the learining experience.
DenLors Tools Plus LLC sells quality automotive specialty tools auto shop supplies and car service equipment. Free shipping $199. Automotive mechanic repair tips with how to info and more!
2002 GAGT
- Street/Strip 3500 Heads - WOT-Tech Comp 3500 LIM - K&N Drop In - Magnaflow Cat and Muffler
- Eibach Lowering Springs - Bridgestone Potenza 225/35/r16 - Drilled and Slotted Rotors - Ceramic Pads - KYB GR-2's
- Big 3 Electrical Upgrade - Kicker SX650.1 Monoblock - Kicker CVX12"D4 Sub
- Ported Box @ 1.88^ft to 34hZ - Alpine CDA-9884 - Cadence 6.5" Component's
http://www.cardomain.com/ride/391881...am-gt-sedan-4d
An Ode to an Over-Torque
There once was Clumsy Mechanic
Who made our Friend Skyler Feel Panic
When the Mech Over-Torqued...
Skyler's Studs became Borked...
So much for the Clumsy Mechanic!
And then Skylar, in Need of a Fix
Came to 60DegreeV6
With his Blood on "Slow Boil"
Used a Smart Helicoil
And Shared with Us all his New Tricks!
The Story now comes to an End
(It Ends Happy, with just a Slight Bend)
"Here's Mud in your eye! I extracted the Die!"
And now Skylar can beam a Broad Smiler!
A Job Well Done....and DONE!Last edited by 60dgrzbelow0; 02-09-2011, 10:32 PM.
Well stated!
I'm very happy I came here and I am now a member of 60DegreeV6 Forum!
Tons of good advice and wisdom here! Thanks everyone for your help!2002 GAGT
This was partly of help to me, except now I have a helicoil for the wrong size bolt in the head of my car.... I now have no clue what size I need because I was not aware that the rocker arms were different.... This is my fault for not double checking and now I have to figure out how to fix my screw up.
uhhh....ummmm, is it the thread pitch different or size or metric to standard? you might get lucky with the proper heli coil, and tap being the same, if not, i dont reccoment double heli coiling, OR possibly check into the 10mm rockers, i dont know if they have a different bolt size all together or just the head, if thats the case you could easly grab them from a wrecker to swap all your rockers.
He had 8mm rockers, but tapped for 10mm because of a thread on here. Since I had some spare 10mm rockers, and I live 20 min from him, I gave him one, and he's back up and running.
Brad via Tapatalk-Brad-
