#3 Misfire after LIM Change
  • #46
    I concur with Brad, and I was thinking the UIM that wasn't red and black was not painted. Doh! Yeah, don't do brake clean on paint.
    • #47
      Good stuff! I'd like to do a quick and nice write up about replacing LIMG's including using the rocker arm pry bar, but i'll have to wait till i have to do one of those jobs to take pictures.
      Bob
      • #48
        Bob
        Great Item! I might have avoided this if I had one. But its all for the learining experience.
        DenLors Tools Plus LLC sells quality automotive specialty tools auto shop supplies and car service equipment. Free shipping $199. Automotive mechanic repair tips with how to info and more!
        2002 GAGT
        - Street/Strip 3500 Heads - WOT-Tech Comp 3500 LIM - K&N Drop In - Magnaflow Cat and Muffler
        - Eibach Lowering Springs - Bridgestone Potenza 225/35/r16 - Drilled and Slotted Rotors - Ceramic Pads - KYB GR-2's
        - Big 3 Electrical Upgrade - Kicker SX650.1 Monoblock - Kicker CVX12"D4 Sub
        - Ported Box @ 1.88^ft to 34hZ - Alpine CDA-9884 - Cadence 6.5" Component's
        http://www.cardomain.com/ride/391881...am-gt-sedan-4d
        • #49
          An Ode to an Over-Torque
          There once was Clumsy Mechanic
          Who made our Friend Skyler Feel Panic
          When the Mech Over-Torqued...
          Skyler's Studs became Borked...
          So much for the Clumsy Mechanic!
          And then Skylar, in Need of a Fix
          Came to 60DegreeV6
          With his Blood on "Slow Boil"
          Used a Smart Helicoil
          And Shared with Us all his New Tricks!
          The Story now comes to an End
          (It Ends Happy, with just a Slight Bend)
          "Here's Mud in your eye! I extracted the Die!"
          And now Skylar can beam a Broad Smiler!
          A Job Well Done....and DONE!
          • #50
            Well stated!
            I'm very happy I came here and I am now a member of 60DegreeV6 Forum!
            Tons of good advice and wisdom here! Thanks everyone for your help!
            2002 GAGT
            • #51
              That has goto to be the coolest thread I've ever read! Great job!!!
              • #52
                This was partly of help to me, except now I have a helicoil for the wrong size bolt in the head of my car.... I now have no clue what size I need because I was not aware that the rocker arms were different.... This is my fault for not double checking and now I have to figure out how to fix my screw up.
                • #53
                  uhhh....ummmm, is it the thread pitch different or size or metric to standard? you might get lucky with the proper heli coil, and tap being the same, if not, i dont reccoment double heli coiling, OR possibly check into the 10mm rockers, i dont know if they have a different bolt size all together or just the head, if thats the case you could easly grab them from a wrecker to swap all your rockers.
                  • #54
                    He had 8mm rockers, but tapped for 10mm because of a thread on here. Since I had some spare 10mm rockers, and I live 20 min from him, I gave him one, and he's back up and running.
                    Brad via Tapatalk
                    • #55
                      bszopi brought me a rocker arm with the 10mm bolt, the car is back on the road, I got it back up and running Sunday. The car is running great, and I am sooo much happier now!!!
                      • #56
                        Yes, thank you so much again, you have been a HUGE help. I have had a few friends come through to help me out and I am thankful to all of my friends that have helped out. As I said bud, if you need help with anything, drop me a line and I will do anything I can to help.
