Does anyone have an idea what is going on here? The crankshaft pulley seems to be pulling away from the engine. You can see that the outside edge no longer lines up with the other pulleys. I removed the belt and tried rocking the pulley with a pry bar and it doesn't move. I also tried tightening the bolt and it doesn't appear to be lose. I am not sure either what that metal ring is that is exposed now.
Any help would be appreciated!!!!
