What about using compressed air to push the oil?
I considered making an oil reserve tank that captures start up oil pressure and holds it until the next start up. Turn the key and open a valve that pressurizes the system rapidly.
Allowing for good oil pressure during initial cranking. The valve would shut once enough idle time has passed, repressurizing the system for next start up....or if the engine sat long enough, prime with a bypass switch to release the pressurized oil into the oil system.
It would be a great component for longetivity.
