I am in need of some help and technical advice on the following idea for a new build:
On the wings of the success of designing, building and proving out "The FrankInjector Machine" for the thorough cleaning and re-conditioning of Fuel Injectors, I have it in mind to borrow the Pneumatic Section of the aforesaid device (or build and use a new one exactly like it) and create an Operational Pneumatic Engine Pre-oiler that will obviate the need for the removal of the OPD (Oil Pump Drive) and the temporary insertion and use of any Mechanical or Electrically Driven Pre-Oiler. If made well, this device could save many extra hours of work, including the need to remove engine sub-sections or perhaps an entire engine to accomplish this task.
CLEAR BRAIDED PVC HOSE 3/8 INCH 250 PSI 25 FT HA16-025
CompCam Engine Break-In Lubricants
The Pre-Oiling Machine would find its point of oil entry to any engine block at the position of the Oil Pressure Sending Unit. This would require the temporarily removal of the OPSU to allow the high pressure clear re-enforced PVC tubing and fitting delivering the Engine Break-In Oil and other lubricants as needed, access to the engine oiling system at its pressuring inception point.
I am suggesting that no other modifications are necessary to the existing mounting stand that I use to hold "The FrankInjector Machine" hardware. In lieu of having to start designing something from scratch and having to change over to a Very Large Volume High-Pressure Oil Container, Instead, I am suggesting that I can employ that same Aluminium Cylinder at present being used to hold the EFI Cleaning Fluid and simply fill the cylinder with the required mixture of Engine Break-In Oil and Special Additives to protect the precious new bearings and rings in fresh engine builds or revive the vacant or dry oil galleries and bearing surfaces in engines that have been dormant for extended periods of time. The volume of this oil would necessarily be much greater than the small Aluminium Cylinder can hold, so instead I would attach a coil of high pressure (proofed to 250 PSI) clear, reinforced PVC hosing 25' long with a .375" Inside Diameter.
The clear coiled hosing would serve three purposes in this design: (1) The 25" length of hose would allow for a substantial quantity special, premixed lubrication to fill up that long length of tubing and act as the means of extending the storage capability of a sufficient quantity of lubricant instead of requiring a larger primary oil storage container. (2) The clearness of the tubing would allow the User/Mechanic to actually see exactly where the fluid moves along or ends and/or any air pockets that may be present in the line. As long as the Aluminium Cylinder is constantly being refreshed with the oiling mixture until the tubing hose is filled up, no air can invade the PVC line, assuming that the filling and refilling processes occur first with the purging of air from the hose all the way up to the attachment fitting and then prior to its being threaded into the female port of the Oil Pressure Sensor Unit located on the Oil Filter Manifold. (3) With such a long length of hose, it would be no trouble to move the stand supporting all of this apparatus close enough to either an engine stand or a vehicle very near thereto, and still have enough length to be guided along and inside any engine compartment for the purpose of easily attaching the PVC hose to the vacant female Oil Pressure Sending Unit port.
I have used metered pneumatic sourced by a typical air compressor tank and delivery lines to accurately and reliably pressurize the EFI Cleaning Fluid during all the regimes necessary to emulate normal fuel pressure for the 3.4L engine and the same will be possible using the clear PVC hosing which has been proof-tested to 250 PSI: well above the rated maximum oil pressure attained with the in-dwelling mechanical oil pump of our V6 engines.
The information and guidance I require knowing for this project is as follows:
(1) What is the volume in fluid ounces of a length of PVC hose measured at 25' L X .375" ID...?
(2) What is the Maximum Recommended Delivery Pressure of any Pre-Oiling Fluid Mixture sufficient to deliver enough special lubrication to all of the engine bearings and inner surfaces being protected... and NOT burst the Oil Filter Cannister ( if that needs to be considered in this design} ?
(3) What is the volume of Oil in Fluid Ounces required to fill all of the Empty Oil Galleries and Oil Passages as well as all Bearing Surfaces inside the average V6 Engine Block? At a minimum this information is critical in avoiding pre-maturely de-pressuring the aluminium Cylinder before actually reaching all of the areas requiring proper lubrication.
(4) What is the size of the thread/pitch count of the high pressure fitting on the Oil Pressure Sensor (Sensing Unit) and is there a swivel design available of this type of fitting that allows for high hydraulic pressure and provide the ease of being inserted and screwed tightly inside the Oil Filter Manifold?
If you have seen the results of the design and development of "The FrankInjector Machine", then you know that when I put my mind to a project... I will make a sincere effort to ensure that it really works as intended. So I would value any and all constructive ideas and criticisms on its design and its improvement as things progress.
