OK, I'm having several very strange coolant issues. First off, it's an 01 Monte Carlo, 3400 block...the LIM is leaking, and the motor has over 140k miles on it, so I'm most likely not going to be replacing it. The temp sensor went out at about 120k miles, and I replaced it, and it worked fine up until about 135k, when it failed again...I replaced it again, and it stayed broken. Here's the weird thing. You reset the ECU by pulling the lead on the battery...and when you hook it back up the temp sensor works fine until about 25 minutes into your first trip, after it's warmed fully up to temp, the readout on the sensor suddenly starts slowly and steadily dropping, then when it gets down to about 1/4 of the way up the gauge it just drops like you flipped a switch, and the ECU turns on the fans permanently as the failsafe and the temp gauge never budges at all no matter how many times you restart the car and such until you reset the ECU again, at which point it starts working again, and repeats the pattern.
Then today the low coolant light came on, and the system was about a quart low in the radiator...topped it off, but the low coolant light didn't go away. So...I mean it sounds like the coolant level sender is whacked...but with the temp sensor all messed up too, there's literally NO way to know what's going on in there...any ideas? Anyone ever seen a temp sensor gauge do anything like that before?
