Swapped out a burned up engine (lower intake man gasket/coolant/oil) in a 2005 equinox with a pontiac torrent 06 3400 engine and had to have the dealer do the tech II scanner deal on it to get all the sensors to work together and he was able to get it to start but then noticed there was no oil pressure, dash guage and connect oil guage tool. He also looked into the valve cover and saw no oil was pumping. The engine I swapped in was a 67,000 mile motor with good looking oil. Wondering if I need to swap out the oil pump with a new one (they wanted $1,000 to do it!!!! WTF????) since maybe the pressure relief valve is stuck, also wondered abotu the pressure switch but that doesnt explain the visible "no oil" issue.
Need some ideas here guys.. Thanks a bunch!
