So i got my motor and trans out of my 05' Monte, i'm going to basically strip it down, clean and seal up with plastic till i get the parts that i decide on needing. i'm throwing in a cam, and porting the top end. i'd like to quickly check one rod and main bearing for a basic judgment of the condition of the bottom end, so my question is which rod and main bearing is mostly under the most stress and to be worn more than others. This is going to basically be a slap and go process with new gaskets and seals, and cam bearings. i'm not sure if i should mess with the bottom end and throw in new bearings while i'm there.
EDIT: motor has 90,000 km with strick synethetic 5w30 oilchanges every 5000km, and the bottom of my lower intake was absolutly spotless if that helps, no carbon or sludge build up what so ever
On a side note, i'm going to be gearing down the trans to a 369:1 or 3.73:1, getting a HD tourqe converter, and a bunch of upgrades to make this thing haul, i'm happy i work at a tranny shop that they can figure this stuff out
While i've started a new thread, i'll ask these quick questions:
I would like to know if i could build a cam bearing install tool myself and correctly install them.
Can i transfer a tune from HPT to EFI live for a base tune
What fuel system parts should i upgrade for a ported 3400 top end with TB, and a Street/Strip or Strip cam, as in fuel injectors, or adjustable FPR
Thanks all for any answers.
Bob
Bob
