3.1 Tripped an EGR
  • 3.1 Tripped an EGR
    Got the '99 Monte Carlo 3100 running this last weekend. The CEL came on and I took it down to AutoZone to have the Code read. Was told it was the EGR Valve. I have not troubleshot it yet. But I did look at EGR prices. They range from $92 to 185$ (Borg Warner Lifetime Warranty).
    If it turns out it is the EGR Valve and not something else like wiring, could someone suggest a Brand that's reliable but still not expensive?
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    In a word . . . no. If you want quality, expect to pay for it. First, take the valve off and check to see if the pintle is stuck. If it is, you can take a torx bit driver and gently turn the pintle on it's seat. Then press all the way in and make sure it doesn't stick open. Also inspect for pieces of carbon that may be holding it off it's seat. Make sure the connector is seated when plugged in and also that it is mounted the right way on it's support. The linear EGR is a fairly reliable design and mainly suffers from carbon buildup during service.
      Thanks for the reply.
      I cleaned the face of the EGR Valve and the Pintle as much as possible before installing it with new gaskets.
      If it checks out electrically, can I soak it in GM top end cleaner? Will that clean the valves Pintle and interior without damaging it?
      jogasz28
      ______________
      '68 RS Camaro,
      '99 Monte Carlo LS
        Also check to make sure the EGR supply from the exhaust manifold is clear, as well as the path from the EGR into the intake. I had a 99 GP 3100 that had a solid mass of carbon from the EGR into the intake. The error for this car was an insufficient EGR flow error. Took a bit of carb cleaner and a piece of wire to get it all out, but it ran fine after that and hasn't tripped an EGR error since.
          I do not recommend soaking the EGR valve in anything. A quick mechanical clean up, make sure it isn't sticking open and put it back in service. To quick check the ports, just fire the car up for a few seconds with the EGR valve still removed. Make sure the intake port sucks and the exhaust port blows (pun intended, and no...I don't have two girlfriends named intake and exhaust ).
            LOL! and i'm with what this guy says, strip it and clean it. its simple and worth while.
              Well...it HELPS if you remember to attach the connector to the EGR Valve.
              Removed the Battery Negative to reset the Code. CEL went out....Life is Good!!!
              My embarrassment is truly overcome by my Happiness.
              This engine is running GGRRRREEAAT!
              Thanks everyone.
              jogasz28
              ______________
              '68 RS Camaro,
              '99 Monte Carlo LS
