I need to remove the oil pan on my 1996 Grand Prix SE 3100. The heads are off as I need to remove the pistons. I don't have an engine hoist either.
Can anyone give me some instructions and precautions as I am stuck. I read the manual several times but it leaves me still confused. I do not want to start removing important bolts w/o knowing exactly what I am doing.
I was told once a while back I could lift the engine block slightly by placing a 2x4 under the tranny pan and jack it up slightly.
Can it be that easy? Just raise the block slightly and remove the blocked bolts?
I am stuck and need help. I need to get this car on the road soon. Piston #6 was cracked when the intake valve seat came loose during heat soak. Both the head and the piston got chewed up a bit but the cylinder walls are still in great shape. I started her up and heard the noise and instantly shut it down. I took it apart down to the heads and saw what had happened. Now I have new heads, new forged pistons with some strong rings and a pair of MLS Head Gaskets for boosted applications.
The good side of this is I will finally have forged pistons so I can safely hit 16-18 psi boost.
Please help, thanks
Please help, thanks
