my 90 APV is still not running right. its not a definite miss as it is just running rough, most noticable under part throttle operation. give me any idea of what to change and i will do it.
so far i have done:
refurbed injectors
rebuilt throttle body with new regulator
new cap, rotor, plugs, wires
new exhaust including converter
checked all wires
checked all fuel lines
new fuel filter
new fuel pump
new o2 sensor
cleaned IAC and verified operation
checked TPS and voltage went from .5 to 4 with no spikes along the way
changed MAP sensor
changed coolant temp sensor
the only 2 things i can think of are a coil or ignition module getting weak? i get no codes, it is charging good and the battery is new.
so far i have done:
refurbed injectors
checked all wires
new fuel filter
new fuel pump
new o2 sensor
changed MAP sensor
