We've got a 1996 lumina 3.1 that has been great until this year. We had the intake manifold gasket replaced, and soon after that we started having real problems. We would be driving along and then the car would go dead - no symptoms otherwise. We could wait a while, then it would start up and run fine for another two or three weeks. Took it to a shop and they changed out a bunch of things trying to find the problem: camshaft sensor, PCM, two reman injectors, new injector wiring harness, egr, crank position sensor. I've had the ICM checked and it's fine, and the coil packs are fine as well. For the last couple of weeks if the car was cool then it would crank right up and run very smooth and then after heating up it would die. It's now to the point where if the car has been cooled off you can crank it and it'll run rough for about a minute, then after it heats up the fuel pump stops getting power.
Fuel pump has just been replace, relay works fine. Something seems to be heating up and telling the computer to stop sending signal to at least the fuel pump if not the injectors as well. I was hoping it was the oil pressure switch not working right, but we've also bypassed it by sending a constant signal to the fuel pump and the engine still dies. Any ideas would be helpful.
