3100 sfi not starting!!
  • #16
    Have a look and make sure the pulleys are lining up and not cock-eyed slightly. Make sure all pulleys turn. Check belt tension and finally, it may have just been a bad belt.
    P0336 is a crank position sensor code. Not sure which one but if your engine still runs then it must be for the 24x sensor on the inside of the crank pulley. It could be that the belt damaged it or the wiring when it broke.
    1995 Grand Am SE
    • #17
      Check ALL pulley's that the grooves are straight and none are bent.
