I'm continuing the top end rebuild.
I pulled all the lifters and cleaned them and reinstalled them.
Cleaned both heads and replaced the oil pump O-Ring.
Questions:
Can I reuse the original Head Bolts?
Should I use the OEM exhaust manifold gasket setup with the shield and
gaskets on both sides of the shield? Or is there an improved version out there?
I've got 2 broken exhaust manifold studs that snapped 1/4" below the head surface.
I'm soaking them in solvent now. Should I use the Easy-Out method? Or is there
an easier way? Again, should I go with OEM studs? Or are there improved versions out there?
If not OEM please recommend Brands.
TIA,
Questions:
TIA,
