Well, bought the van dirt cheap cause of course there is engine problems. Apparently this van has 200K on it but the engine has already been replaced at some point with one with only 70K, insider knowledge of the place the previous owner took the van to for the engine swap I know it's a shady shop so I have some doubts the motor they put in had only 70K
Anyway... story goes guy was driving down the highway, noticed it was overheating shut it off asap since last time they overheated the engine it needed to be replaced. He had it towed home, and it sat for 6+ months before I bought it. We tried to start it, turns over but only kindof coughs a little, and noticed the rad was low maybe empty couldn't see all the way down so we put some water into it and it started pouring somewhere out the back of the motor.
So, I'm guessing LIM gasket, but the fact the van isn't starting has me wondering about the condition of the head gaskets, would explain the poor startup/coughing. So, I'm thinking tear the motor out and see what's going on. Anyone got a detailed explanation how to do this in a Montana? The subframe needs to be dropped out from under the van correct?
And if I decide since the engine is out to do some replacing, is there a list I should do? Timing chain/belt? Thermostat? Are injectors an issue with these motors?
And gasket sets, of course I'm going Fel-Pro but I was curious between these 2 kits
HST9071PT1
HS9071PT1
Do I really need the premium armored metal one or will the other one work just fine? I mean it's a minivan, and the system will be flushed of all Dexcool and replaced so I'm not sure if it's worth it to get the best... plus I can get a smoking deal on the cheaper set
Then I guess I need new bolts for the LIM... do I need new bolts also for the head? Whats the torque specs for those???
Any information would be appreciated, hoping you guys can help me get through this overhaul.
Side note... I also have a 3.4L engine with 155K in a '02 Impala... I know it runs but was planning to sell it if I could get the other motor in the Montana going... or do you think I should consider swapping them out doing the gasket upgrades on the Impala's motor and sticking it in the Montana?
HST9071PT1
HS9071PT1
