Well, after way too long, I'm finally back on replacing the Head Gaskets and on up on the '99 MC.
I'm now at the point of having the upper and lower intake manifolds removed.
I know I should identify which pushrod goes where, but should I also identify the rockers and nuts?
Is the Factory Manual's valve setting procedure the best way? Or should I find each lifters mid lash point (a bit time consuming).
And speaking of lifters, can I bench test them with a pushrod?
When I rebuilt my '95's 3.4 I sent the Fuel Injectors to WitcHunters to be Tested/Repaired as required. Are they still the best Injector rebuilder to use?
