I have been smelling gas fumes for a while after (randomly) running the AC but every time I stopped the car it seemed to go away. This time I finally caught it I believe. As I sniffed around under the hood, the smell got quite strong right at the evap canister.
I was not able to pull the reservoir off to check it out, but did inspect the lines which looked fine. Question is, other than an obvious crack or something, what else could cause this and is there a common issue/fix?
I don't know if it could be related or not, but sometimes after the car has been shut off, sits a little, and restarted it seems to hesitate for the first little bit. If I give it gas, it is like it does not want to respond or breaks up. Normally after the first two stops in my neighborhood it will clear out and act fine, or if I give it more throttle.
It also seems my gas mileage back and forth to work is down. I used to get ~26-27 MPG in summer, now I may be lucky to see 25-26, but normally is ~24.
