I was working on a 2000 3100 yesterday, and this is the newest 3x00 i have worked on yet. I was interested to see that GM switched to some small narrow plastic injectors. When it came time to remove the rail from the LIM, the rail just would not budge. I pried here, and there. I shot the injector O-rings with WD-40 maybe to help loosen them up... nothing. I finally just pried for all she was worth, and said, screw it, something will just have to break... and it did. one injector on each rail broke its little garbage retaining lock, so its not reusable. and left the injector in the LIM. The four injectors that did stick with the rails, shed there black plastic O-rigns AND the black plastic caps that go on the tips, and dropped them right down the intake ports!!! luckily none of those valves were open or I'd be doing a HG job as well. I was able to remove the LIM and then fish out the black caps from the intake ports with a small screwdriver. I had to go to the J/Y today and get some more of the metal retainling locks. Finally, i tried to get the other two injectors out of the LIM. It was on my floor, and i had on leather gloves, and i pulled with everything i had, and i could only get one out!!! The last one eventually came out the same way but not before i said alot of cuss words, and nearly broke it.
So, why in the world did GM go from a nice robust injector that would pull out of the LIM with little resistance to these little petite plastic slivers that look like they'd break if you looked at them wrong? Did i go about doing this all wrong or something? Im telling you, it was rediculous. There must be a better way....
