Bad fuel pump ground?
  • Question : Bad fuel pump ground?
    2003 Chevy Malibu 3.1/ 8 months ago I thought the fuel pump was bad and I had played with the relays and then it started. I had the code it was throwing but I didnt worry about it untill it happend twice this week. It sounded like a bad ground. Is there a quick fix?
    If by quick fix you mean rig, I would lean towards no because rigging usually leaves you stranded on the side of the highway 10 miles from home in the rain. The best way would be to find where the relay that controls the fuel pump or the fuel pump itself (whichever is giving you the problem) is grounded and repair the ground or ground it somewhere else if the area cannot be cleaned enough for a good connection.
