This is a new one. The wagon has suddenly developed a possible fueling problem. I've made a video of the symptom, which can be viewed at the following address: http://www.youtube.com/watch?v=O80WK8kMzOk
In summary, when you open the throttle, regardless of what gear it is in, it will bog down severely, sometimes enough to stall. It's more pronounced when in a drive gear, either forward or reverse. Could this be the throttle position sensor, the fuel filter, or the fuel pump? ICM and coils are somewhat new (about a year and a half old), and fuel injectors are about two years old. Fuel filter is nearly three years old, and the pump is of unknown vintage, possibly stock. Also, I later discovered that what I unhooked was actually the IAC, and the TPS is directly below that. I don't think it's the TPS, because I just went out there and undid it with the engine running and it died.
