In mid 1980s (84 for example) the 2.8L in passenger cars like the FBody came with an ECM, which took inputs from things like TPS, O2, etc. and controlled carb mixture and vac advance...
Essentially the same 2.8L was also available in trucks like the S10 WITHOUT an ECM, O2, TPS, M/C solenoid etc. It had a slightly simpler version of the same carb and the distributor's advance was controlled centrifugally and by vacuum.
Q: All other things being equal - how would these two variants compare in efficiency (mileage)?
