About using "straight" EFI Cleaner in an "ON-THE-VEHICLE" scenario... FOLLOW SUPERDAVE'S ADVICE ABOUT ALWAYS MIXING THE CLEANER WITH SOME TOP-TIER GASOLINE!!! When I have made reference in the past to using pure Chevron Techron or a mixture of Lucas Oil and WD-40... please note that this is strictly for use on "The FrankInjector Machine" as there are no other components being affected by this pure cleaning solution. If you try and BURN pure EFI Cleaner without other very high octane gasoline added as a "buffer" to this mixture ...you will run the risk of high powered detonations to the piston tops... or burning the edges of your valves in the heads like Crispy Fried Pork Rinds!
