I want to do this the cheap way.
The Setup:
Meaning, clamp a piece of fuel injection hose to the feed of the injector, fill the hose with gm top end cleaner and then use regulated compressed air to force it through at around operating pressure. My thought was that I could use a 12v source to open the injector and allow for flow.
My question:
Is there harm to be done by 'holding' the injector open? It is designed to be rapidly pulsed, so is there a chance the coil can be damaged by holding it open? Will 12v right off a battery be ok? I don't want to fry them or damage them by holding them wide open for a minute. What if the seafoam runs out and I force some air through the injector... bad news?
This is for a set of used injectors that I want to give some kind of cleaning to, and also be sure that they dont leak down when there is fuel pressure but no signal to fire.
The Setup:
My question:
