I have a 2000 Grand Am 3.4 that I had to remove the crank pulley on to locate and fix a small oil leak. Turns out the leak was from the oil pan gasket...that's all fixed.
Now onto the REAL problem.....I can not get the crank pulley back on for the life of me. I've tried heating the pulley up and lubing it up and it won't go on more than a 1/4 of an inch. I did not remove the keyway on the crank so that's in the same place it was.
Any ideas what could be causing this or anything else I could be missing or try??
