Hey everyone, I finally finished buttoning up the install of my replacement engine and started it up for the first time on Thursday. I'm pleased to report that this engine sounds like a good one, runs smooth with no noise. I do have a few issues though so I have some questions, but I'll start with this one first:
When cold this truck idles/runs like a carbed engine does without a choke. It'll start up quick enough, but I have to nurse the throttle to keep it running or it'll die out. Not necessarily because of lack of idle either, if I hold it at a quick idle it'll still die out, I have to nurse the throttle up and back off. If I continue this until the engine reaches operating temperature it will then idle fine on it's own.
I found the vacuum line that feeds the 4wd and heater control is pretty wasted and leaking so I disconnected it and capped of the port for the time being. That helped a little but not much, all other vacuum lines appear to be okay and hooked up correctly.
Where do I start on this? It's a '87 S15 with the 2.8L V6. 5 speed, timing set at 10 degrees.
TIA!
TIA!
