Hello everyone,
1996 Grand Prix SE w/ 3100 stock
I decided to replace all gaskets down to the heads since I am flushing the dex-cool out and going green. There was no serious water issues in the crankcase. Though, I was probably only weeks away from bursting the coolant gasket. It was cracked and warped out, definately ready to burst.
Anyways, I have a few questions.
When attempting to remove the stock camshaft, it seems to hit something 1" out. Everything has been removed such as lifters, sprocket, chain, torque plate, ect.
The camshaft is being removed through the wheel well. I modified the body by cutting a 3" diameter hole allowing the camshaft to go through. The wheel is also removed so I have a straight shot to pull it w/o having to raise the block. I also fashioned a bolt on plate to cover the 3" hole I created.
Well, I used a long bolt to attach to the camshaft to act as a removal tool for grip and control so I don't damage the bearings.
No matter how I manipulate the camshaft, it will not pass some obstruction 1" into removal. I'm sure there are no lifters over looked and according to the procedure, I have all components removed for camshaft removal. When the cam is 1" out, while turning it, I can feel the bearings as the object blocking it from removal. I tried gently rotating and shifting it's position to work it through while not damaging the bearings.
No matter how I approach the removal, it will not budge past that 1" mark.
Now, what am I missing or could there be something wrong with the cam bearings?
Also, the camshaft rotates freely when in it's proper place. Though, the rotation is lightly stiff even with pushrods removed. It will not spin on it's own after I spin it. It feels smooth in rotation but almost like there is syrup in the bearings.
Is this normal rotation? Or should my camshaft spin free like a skateboard wheel?
Thanks much guys. If there was any forum that could answer my problems, it would be here.
