Okay so i have this 3400 i just picked up and after trying unsuccessfully to do a compression test, i decided to tear into the motor. I found that the cam had snapped in two almost right in the middle.
It looks as if it spun the two center cam bearings as well, one is still in place, and the other fell out of it hole. My question is, due to the fact that the one bearing was removed from its hole by the cam, did it trash the block? Or is this easily remedied?
Thanks
Pics of the cam halves:
Basically im just wondering if im f**ked on the block, or if i can stuff another set of bearings in and be okay? I dont have pics of the bearings cause i couldnt get the one out, and the other is still in its bore.
Thanks
