Charging system drain?
  • Question : Charging system drain?
    My heater fan, when at full speed, slows when i depress the brake pedal. when on the throttle the fan increases speed significantly. Anyone have an idea on the cause? I am thinking alternator, but the brake pedal issue makes me reconsider.
    Some temporary voltage drop seems to be normal for GM cars. Mine always dips on the 3-2 and 2-1 shifts while decellerating. But the voltage should always rebound to ~14.4v at idle unless something is putting a big drain on it.
    Use a voltmeter and check the battery and alternator while the engine is running and off.
    1995 Grand Am SE
      it does sounds like the alt can't keep up with the changes in electrical draw. or your wiring is at fault.
        Pressing on the brakes will cause a load on the engine, which will then cause the alternator to slow down. That is why you see a dimming when you press on the brakes. But yes, it sounds like the alternator is starting to go out.
          Thanks for the replies guys. I am going to swap in another alternator that I have in "stock". see if that makes a difference. its not new, but it may give me an indication....dont have a voltmeter and im a student so i cant really afford to buy one right now., would almost prefer an obd II scanner.
            check your grounds as well. could be a bad/weak ground... i had simmilar issues when my grounding issue was happening.
            Shane "RedZMonte"
            1992 Lumina Z34-VIRGIN (RIP)
            1992 L67 Lumina Z34 (SOLD)
            1990 Turbo Grand Prix (SOLD)
              Ground issue, hmmmm. good point. i will clean some of them off tomorrow. I could see that being a contributing factor. the alt may be on its way out as well. If anyone has had issues with the power window switched from the 1996 era olds style switches i just fixed mine. pulled the drivers switch out and pulled it apart. the window lock switch had corrosion on the terminal under the lock button. = water from the window was the culprit. and here i thought my switch was bad.
