Hi everyone,
Newb here, so forgive the questions... I've already searched, and found some answers here, but I wanted to get a variety of opinions before I make my final decision.
I have a 2003 Buick Rendezvous 3.4l V6 (from what I've read, it's the LA1 engine) with 135 000 km on it (that's about 85 000 miles).
I noticed a very slow coolant leak (a few drops on the underside, but not enough to make a puddle in my garage). I decided to flush the coolant system, and maybe use a stop leak (like Barr's or Prestone), and looked into it a bit more. Much to my surprise, I found out a lot about dexcool, and now I'm all nervous about my engine. I don't have any evidence of sludging in my cooling system, but I haven't really looked all that closely.
Basically, I've decided to do a complete flush, and refill it with Prestone (even though it's ethylene glycol, too). I can't seem to find the green coolant anywhere, and propylene glycol seems to be difficult to find, too. Basically, I'm going with Prestone because it's what my father-in-law used to use, and I don't know any better. I could also use a store brand, or Peak, or even dexcool again (although I'd rather not).
However, when looking through my service manual, it says a few different things. Now I'm getting all confused...
Under general coolant system flush, it recommends to use a flush kit (like the Prestone Flush 'n Fill), but I'm hesitant to cut open a heater hose. It also mentions that I need to turn the heater control to full hot.
Under the cooling system section, it lists instructions where you drain the radiator and the engine block, and fill it with water. It also instructs me to remove the thermostat (which the other section neglected to mention). It doesn't mention a flush kit or the heater control. I then have to run the engine with only water in it for 20 minutes, then drain and fill again and again until there's no trace of coolant. Then, I can drain the system a final time, add half the coolant capacity of the engine worth of concentrated coolant, then top it off with distilled water.
Which one do I listen to? I had originally planned to follow the cooling system instructions, but I'm not sure which one is right. Do I need to pull the thermostat and replace it every time I drain the system? It's kind of a PITA because I have to remove the exhaust crossover pipe to get to the thermostat.
This is my first cooling system maintenance, so I'm a bit nervous. Please weigh in with your opinion.
1) Do I need to pull the thermostat to flush my cooling system?
2) If I've already pulled the thermostat, should I just go ahead and replace it? What's the life-expectancy on a thermostat?
3) Should I flush using the flush kit, or just drain the block and rad?
4) Is there any danger in using a stop leak product?
5) Should I use a chemical flush, or is that a really bad idea?
6) Is there any particular brand of coolant that you recommend? What base is it?
Sorry for the long post, but I'm full of questions. Thanks for the help!
