Valvetrain noise after rebuild
  • #16
    Update...
    Well I pulled the intakes...ughhh.. and found the lifter on #3 Exhaust wasn't pumped up so I've replaced it along with roller rocker arms from a 96 3.4 from pull-apart. The engine now runs great. Nice and smooth. Lots of pep for a 3.1. I appreciate all of the responses that I received from this forum. This site has been a great help to me. Once again, Thanks. I really appreciate the information.
    • #17
      Well I was going to say bent valve but you have compression on all cylinders so thats a good sign. Bringing each piston to TDC is not the correct way to adjust the valves. The correct way is to rotate the engine and watch the rocker arms. When the exhaust begins to open adjust the intake valve and when the intake valve fully opens and then closes slightly adjust the exhaust valve. I would also add 1 full turn after zero lash. When you replaced the cam please tell me you used new lifters.
      Are you saying that you replaced the cam during all of this? If you did...Please tell me you coated the lifter "feet" with either Moly-D or some other type of Engine Assembly Lube and added some Cam Conditioner to your engne oil...and also that immediately after the first start of the engine, that you raised it right up to 1,500-2000 RPMS for about 20-25 Minutes to properly condition your new Cam's Lobes? (and then immediately afterward. you changed the Moly-D clogged Oil Filter and put in a fresh one with some HQ motor oil). If not... there is always a chance that the lobe under the old lifter that is "ticking" was damaged ...or wiped...
      EDIT: Ooops...Roller Rockers...Damn... My Bad... Sorry about that..(Whew!)
      • #18
        I used pre-lube greese and everything and also primed a new oil pump with my drill. On initial start, I used 5w/30 autozone branded oil with an AC Delco filter. The engine was run around 2500 RPM for about 10 minutes (with the lifter ticking). I changed the oil with Castrol Full Synthetic 5/30 again with a new AC Delco filter after 2 hours of runtime. Hope this was right. The engine sounds good. Thanks.
        • #19
          Roller engines don't need that break in for the cam.. or special oil
          you just cote the cam in assembly lube and the rollers on the lifters (which have been soaking in oil) and slap it all together with some lube on the pushrod ends and the rocker tips and fire it up.
          • #20
            There is NOTHING more nail biting to me than the re-start of a fresh build... hahhaa.. I've gone through it twice now, and my hart has gone to my throat both times.
