I have a 91 lumania z34 and it truns off on me if i shift it out of gear so i have to keep my foot on the gas in order to keep it runing if it turns off on me i just trun it back on and it does
INFO
It's the metal sensor that sticks out about and inch on the fire wall side of the engine. It should have a 90 degree plug, its black and the are 2 star bit screws that hold it in the throttle body. At least that where it is if it's 3100, 3400. I'm not familiar with any of the larger engines. cept the 38001998 Chevy M VIN Mali LS with 99 Olds J VIN 3100 Swap
Sealed power skirted hyperuetectic pistons, LS6 Valve springs, Manley keepers and retainers, Custom short ram, header back, Tuning by Performance Dyno, 3400 TB, MSD Coils and wires, A/C Delete, Gasket matched heads and intake manifolds, 180 hypertech stat, Cat delete, 2 1/2" header back.
It also has a 4 wire plug since it's basically a stepper motor.-60v6's 2nd Jon M.
