I'm little lost about how to removed pushrod out?
I went to junk yard and I found other same car as mine. Someone already remove lower intake manifold and took it with them. I just like wow perfect. I should practice how can I remove that when I will do that on my car later. I try to remove push rod myself but nothing work. How world can you remove the pushrod out? I need to remove that for put new metal gasket to replace plastic gasket out. I know it is mostly problem for 3100 engine. Do I need special tool or what?
I found this helpful step by step link but it doesn't say how to remove pushrod.
My plan is get that metal gasket with many other gasket what my engine need.
Maybe get a new lower intake manifold?
Day 1: On May 25th, I removed upper intake manifold, valve covers and some ramdom stuffs.
busy busy busy at work....
Day 2: I currently working on my engine last Saturday. So far I have removed steering wheel pump, fuel line (it was painful to get out but still can't remove behind where it is connect from fuel line. It was big metal nut. That's one I can't get it out. I pull apart hard as I can but it won't go out). I removed 6 bolts from lower intake manifold. I need buy small tool to get 2 bolts out. It was "buried" under lower intake manifold.
There is my engine look right now.
![](http://i243.photobucket.com/albums/ff171/palsut/DSC03697.jpg)
I'm on 1 week vacation next week.
I should have it done next week if I knew how to remove the pushrod. If not then I will tow my car to dealership to remove pushrod and re-install everything for $562.00. Sound good deal?
*edit* not sure if wot tech have warehouse or not. If not then I probably go http://www.milzymotorsports.com/ warehouse to grab some goodies. Good product? It is 40 miles from me. Just want finish the engine next week.
![Mr. Green](https://www.60degreev6.com/vb5/core/images/smilies/icon_mrgreen.gif)
