I spied what looked like an Oil Pump Drive for the GM 3.4L V6 engine on eBay for under $20.00 (S&H Included) and since I could never find one anywhere when I tore down the GM 95 3.4L, I went through a lot of trouble to disassemble the stock one from this engine and wound up cleaning out a mound of carbon, gunk and crap that was trapped in the upper bushing chamber, I decided I might as well grab this one while I had the chance. (even if the seller was listing it for an '04 "3.5"...whatever that is)
I thought that since they looked so close in design that even if it had a SBC style slot-drive in the end of the helical gear like the newer ones, I might at least be able to drive out the spring pin and try swapping the gear ends if it looked as good as it did in the picture and everything matched up elsewhere. To my complete surprise...the damned thing had a Hex Drive end on it that matched the stock TRW Hex Shaft...and in all other repects...it was a dead-balls-on match to the one I removed from the VIN "S" motor. Almost...
And so I'm asking the more seasoned members of the forum to eyeball these photos I took and tell me if these very slight variations I noted are something serious to worry about. My concerns are as follows:
(1) The distance from the upper portion of the "O" Ring groove sits about 1- mm lower down than the stock OPD.
(2) The top to bottom length of the geared section is slightly longer than the stock OPD and seems to have been cast, rather than machined from a heavier steel piece like the one on the stock OPD and it tapers a bit more down to the female Hex end of the gear piece. The gear teeth, helical angle, depth and number (13) are almost identical, however, they are just a smidgen deeper on the late model OPD, too.
The two OPDs appear, in all other respects, to be identical, including the fact that the Hex Shaft heights on both are exactly the same when fully inserted and with both units placed side by side on a level surface. I would not bother with all this, but since I'm putting so many other new and upgraded parts in this engine, if I can upgrade the Oil Pump Drive as well at the same time, I'm very inclined to do so. The last consideration is that if anyone is seeking an alternative GM OPD to replace one that is either worn out...or not to be found anywhere...then this one might do as a perfect stand-in in its place.
Thanks for your ideas on this...
-==Bob==-
-==Bob==-
