Just assembled my car from doing a valve job, it has an engine with a distributor 3100 3.1L.
Problem is that I have fuel going, spark is there, starter is revolving the whole thing... but there is no detonation at all. Not in a wrong order, not even a weak one.
At one point I was cranking a lot and pushing gas pedal at the same time, I think I heard 2 puppy explosions (really weak) but they kinda put a little fire to the top of the intake where fuel is spayed, I am not even sure it was a detonation, more over-saturation of gas. I might have over-flooded the engine then...
What should I check for? I am a little at loss... The car acts as if spark plugs are not installed. I was hoping at least at some rough idling until timing is set correctly..
I think I put the distributor on correctly, at cyl #1 at TDC, I put the distrib in and called the plug #1 where it was pointing at. My thoughts that even if distrib is put incorrectly, it still should fire some even out of order, not that it is a good thing but I am looking for any signs of life at this point.. Yet the spark is there, I took a few boots off spark plugs and while cranking it did produce good strong electric pings to the wrench.
Could a distributor be placed such that it would make an engine "inert" ?
BTW, I have a new fuel pump that was replaced like a month before I did the engine. So, the pump and filter are all new, relatively. Spark plugs and the wireset are also bought before the engine started to give me noises (lifters). Distrib cap is also almost new.
So, what should I do?
