Runaway Camaro: TB Stuck in WOT
  • Resolved : Runaway Camaro: TB Stuck in WOT
    When my son first got his 1994 Camaro RS, there were two incidents where his engine stayed in WOT and he lost control of the car. The first time it happened, the car thankfully stalled in a deep patch of sand off the road. I investigated and thought perhaps because his small carpet seemed wedged pretty far forward and wound up under the gas pedal that this is what happened. But I found nothing definitive and chalked it up to that circumstance as being the cause of problem.
    The second time it happened many months later. But this time he was in heavy traffic and somehow, after his brakes faded and failed, he managed to run completely off the road, plowing up a row of bushes instead of cars and people, badly damaging his front bumper, hood, and the drive shaft cross member which I replaced.
    Thankfully, neither he, nor anyone else was harmed. But this time though, I did a better job of investigating and finding the actual cause of the problem. It was such a simple thing, but it could have been disastrous. Here is what I discovered:
    (1) Checked under the dash above the gas/brake and found no carpet/cables binding.
    (2) Followed the dual cables from the firewall to the throttle body (no binding).
    (3) Unbolted and removed the plastic shroud around the cable hook-ups on the TB and cycled the double spring mechanism time and again, I could find nothing wrong.
    (4) Removed the throttle body and serviced it from top to bottom, with two new sensors installed.
    (5) Upon re-installation of the TB and cables, I was slipping the air handler hose around the inlet of the TB when I spied what actually went wrong...
    (6) Whoever had last serviced the unit prior to the Camaro changing hands had REVERSED THE STAINLESS STEEL CLAMP on the air tube from being positioned outboard (left side of TB when facing the engine) and opposite from the area of the double spring actuated, dual cable bell crank on the right side of the TB, facing the engine!
    (7) When improperly reversed, the hex-head of the S/S clamp is moved into a position that allows a right angle piece of the bell-crank mechanism to move up over the hex-head and get stuck on top of the bolt head. So whenever the gas pedal is pressed nearly to the floor, even with the strong dual springs working properly while trying to return the throttle to the neutral/idle position, it simply stays at the WOT position. When this happens, the cables go completely slack and the S/S clamp screw holds the throttle in a WOT position until physically jarred loose or pulled free by hand.
    (When this occurs under normal driving conditions, nothing short of turning off the ignition key (if even possible) can be done to stop a 'Runaway" condition from happening.)
    Whoever had serviced the car must have completely removed the clamp which is normally held in place with the hex-bolt on the left side by a pointed rubber rivet poking through a small hole in the bottom of the S/S band. Some Yo-Yo had actually slid the entire clamp off of the air tube ...and put it on backasswards with the rubber rivet stuck back through the hole in the bottom of the S/S band! The oval top hole in the clamp where the air pipe fits in gives no indication if it is turned around backwards.
    Fortunately...this is one of those things that can be seen as soon as the hood is raised. So those of you owning the 3.4L Vin "S" engines, it might be worth your while to take a quick glance, just to make sure that the S/S clamp screw is on the Left Side of your Throttle Body...and not the Right Side! As for the miserable performance of the stock, hybrid disc/drum brakes in the car, I have since done a complete LS1 brake conversion and the car now stops very nicely with four new, large steel platters!
    Bob
    Seems like a recall is in order...
      Why would your first response not be to shut off the car instead of trying to go with it?
      SpudFiles
      Theopia
      Enjoy life online.
        Teenagers who just got their drivers license may not be thinking about that in a paniced situation. Who's to say you'd react any differently in the same situation? Keep your judgements to yourself.
        Nice catch on the bracket, BTW. It's amazing how the simple things can come back to bite you.
          Thanks for your keen observations and insights into all of this, OldSkoolGP.
          Thanks SappySE107...Cliff Notes...Applied
            Can I get the cliff notes please?
              I did the exact same thing with my Turbo Grand Prix once.. some piece of the throttle body got stuck on a poorly positioned hose clamp. nearly launched the damn thing out of the back of the garage luckily I had the sense to throw it into neutral and shut it off.
              -Tony | gtsdurango.net
              '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
              '90 Turbo Grand Prix STE - ehh.. I'm working on it.
              '92 Gutless Supreme SL - RIP 5.2010
              '90 Turbo Grand Prix - RIP 6.15.2005
                This happened to me 2 days ago! The linkage on the cruise control cable snapped off and wedged under the throttle stop leading to my runaway motor! It does induce a moment of panic. I was lucky and on the highway with room to spare. First instinct was to stop the acceleration via clutch in and then to shut the motor, and finally I keyed back to 'run' so I wouldn't risk locking the steering wheel. My motor did end up zinging off the rev limiter for a few seconds and at 7k+ with no load that just makes you cringe.
                1994 Corvette
                LT1/ZF6
                2006 Dodge Dakota 4x4
                3.7/42RLE
                  GutlessSupreme...
                  jmgtp...
                  I'm sorry to see that you men are making my argument for me to look for this problem ahead of time ...from your own, horrible first-hand experiences. I'm glad that you both used quick thinking and reflexes so you can be alive to discuss it with us. But it really makes me wonder just how many more of us are out there in "GM V6 Land" (and maybe the V90s are susceptible, too?) and are riding around with this Time Bomb ticking away so close to their Throttle Bodies. I'd bet that most drivers would have no idea how quickly things will get out of hand from such a simple mistake...or be as alert and capable as you guys were in getting control quickly. It would be interesting to know what the national NTSB stats are on "Runaway Vehicles" involved in accidents caused by this problem.
                    GutlessSupreme...
                    I'm glad that our lawnmower was also just as lucky to be here today after I ran it halfway over But no, really, I'm glad to hear your son is ok as well.
                    This really could be a serious problem for certain drivers, and the fact of the matter is, this happened to me when I was 17, and I only thought to shut the car off so quickly because I had recently read a forum post where some kid really did launch his Impreza STi through the back of his parents garage because of some kind of throttle problem. He was fine, but the forum discussion definitely pointed out what the obvious response should have been when the brakes weren't stopping the car.
                    After it happened to me and I discovered what the problem was, I thought to myself "wow, I'm an idiot for not having noticed that before," and didn't really give it another thought, but clearly this could be a more widespread problem. The way my clamp was positioned, I don't think it could have gotten stuck unless I went WOT (and I won't elaborate as to why I was WOT in the driveway @ 17 years old ), but that shows the fact that many drivers may never even go WOT and therefore never experience the problem if the risk is there.
                    As the 60* is well over the 20 year mark by now, I'm half surprised that a TSB wasn't issued somewhere along the way, considering that 3 people on the forum so far have said this happened to them, and we're only such a small sample of the 60* drivers out there.
                      I have had this happen to me, but it had nothing to do with a hose clamp. It had to do with a mis-adjusted throttle plate in a custom TB, causing the plate to get bound open at around 3/4 throttle. Can't really remember what I did at the time, but I remember the brakes not slowing me down...
                        My problem was no fault of GM. I too have a custom TB that required modding to the cruise cable to make it work. My failure wasn't a hose clamp but rather the terminal crimped on the end of the cable breaking free and wedging itself just right to hold the TB open.
                        1994 Corvette
                        LT1/ZF6
                        3.7/42RLE
