It looks like the 3500 Engine Specs found on the left hand side of the page may be wrong. I have always been putting in 4 quarts of oil even though the 3100/3400 was 4.5 just because the specs page says 4, but it seems that it may be wrong according to GM.
3500 Engine Specs
3500 Engine Specs
SpudFiles
Theopia
Enjoy life online.
3500 swap, 60degreeV6 1393 Cam, Ported Intakes, Comp Cams Valve Springs, 65mm TB, Custom Pushrods, S&S Headers, 97 PCM with DHP Powrtuner, 2.5" back to dual Hooker Aerochambers, SS Brake Lines, Addco swaybar, KYB's, Intrax Springs, STB's, etc!Tags: None
I tried that oil... Hard to tell if it helped anything... I had Mobil 1 10x40 in when I went to Charlotte... thank god with how hot it was down there.
Also I've always over filled mine a tad since I use the larger filter. I run my 4t60 1/2-1 quart overfull I have a very large aux cooler on it, and I run the engine at 5 quarts total, I would probably be fine with 4.5, but with the RPM's I run sometimes I don't mind having that 1/2 quart buffer to keep the level up there.
