Thank you, people, who helped me to torque rocker arms in the previous thread. I got them torqued perfectly as you have suggested.
Now, it seems like I have to remove the pushrods once again.. Please see the pictures. I am I really this unlucky? Do I need to remove the rods so I can install the gasket by putting pushrods through? On the gasket it says DO NOT CUT. How can I keep the surfaces clean of the gasket for the install then when rods require some lube on install, that is if I have to put the rods through? Do I really have to take rods out now? Something doesn't compute, I cannot be that unlucky..
Second, on the last picture you see that one hole is much smaller than on the other piece of the gasket - the silver port... Not sure which gasket is for the front and which one is for the rear.. My old gaskets look similar but I took them off like 2 weeks ago, I don't remember where that small window goes. Why is it smaller in the first place?
Thanks.
Thanks.
