3.4 camaro rocker question
  • 3.4 camaro rocker question
    im new to the site but i need help asap. my sister has a 94 camaro with the 3.4L v6 i had to pull the top end apart because she blew a head gasket. i have the heads and lower intake back on. but now i have to set rocker arms and im not quite sure how to do this. any tips would be greatlly appreciated.
    Read that. When they tell you to add 1/2 turn past zero lash ignore that. On stock GM studs you must add AT LEAST 1 TURN past zero lash.
