Will a 5 speed tranny out of a 88 beretta gt 2.8 fit in my 90 lumina 3.1 along with the clutch and pedal and all that mess if i were to swap it? Also would the 3.1 in my 90 lumina go into a 94 corsica 3.1 if i swap the manifold and everything so i dont have gasket problems... The motor in the cosica is shot out... would only repair for just a everyday driver cause everything else is like new on it...Thanks abunch! Also if the 5 speed tranny would not go it would be sold. has about 160,000 and shifts through the gears fine but not positive if its 100%...I would guess its just the motor thats shot... I know some of you would llooovvveee it... Thanks again!
5 speed beretta gt tranny
the 2.8 and 3.1 motors are pretty much the same thing... i would think the tranny would at least bolt up to the motor wouldnt it? I just figured everything else would be alittle more difficult... The lumina z34s came with a 5 speed... just dont think it was till acouple years later... Thanks for your info!
yes, the tranny will bolt right up, but i don't know how well the hydraulics would bolt in, the lumina is a much bigger car, so the lines may be a bit stretched to fit. plus i dont think the clutch setup would bolt in, although i could be wrong.
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
There was a 282 gegtrag (same as beretta trans) for the luminas but it was 89-90 or something like that on the 3.1 model. It would bolt up to the motor but the axles, possibly mounts, etc would all be wrong. Pedals and all would need to be sourced from a lumina. Later year luminas with the 3.4DOHC got the getrag 284.
The older 3.1.mpfi will not work in a 94 corisca with 3100. The 3100 has a cam sensor and a 2nd crank sensor. It would throw engine codes and might run in limp mode. Plus you'd loose horsepower. The 3x00's LIM leak can be fixed with metal LIM gaskets. It's the way to go.
What you could do however, is take the 3100 and if the cam bearings are good and the cylinders/rings etc are good and it's just the bottom end that is locked up/knocking from coolant in the oil is put the 3.1mpfi bottom end into the 3100. They share the same crank and rods. Pistons are a bit different I think. So you could do that and throw in a metal Felpro/dorman LIM gasket and be rocking again.... Or find a low mileage 3400/3100 and swap it in.sigpicNew 2010 project (click image)
Im not sure what went out in the motor on the corsica... its a buddy of mines grandmothers... I would guess the same as all of them... Its in pretty good shape but its by no means a cool car... lol... Theres another one right down the street that just went up for sale thats a 4cyl for $900 with only 120,000 miles... Should just junk mine get that and call it done... Better gas milage anyways... Thanks for everyones help and if any of you are from the southeast and need parts let me know... This junk yard by my house i swear has probly 75 to 100 of these sunfires, grand ams, luminas, cavaliers, corsicas, all them... theres z24 cavi's, beretta gts and gtu, z34 lumina, bunch of them... If your not close let me know and i can get it and mail it to ya... Thanks again... gotta figure out what i wanna do... lol
Just found a 92 cutlass convetable that look to be in really good condition on ebay about 45 min from me with a blown 3.1... So as long as he still has it come after the weekend and i finish this job im gonna go take a look. best bet for me so far i think since my motors fine and my cars ugly... lol
