The front sensor is not required for it to run.
3100 issues
Originally posted by bszopi View PostThe front sensor is not required for it to run.
Where did you buy the 7x CrankPS from? If from autozone rip it out and buy one from somewhere else.
But that shouldn't make it back fire through the intake I wouldn't think. It can back fire out the back from a bad CPS though.Last edited by IsaacHayes; 01-26-2009, 06:29 PM.sigpicNew 2010 project (click image)
Ok you say you have spark, good compression and fuel pressure, and your plug wires are in the correct order, right? I'm still not sure if you have the wires in the right order, but assuming that they are, then you need to check the fuel injectors and make sure they are cycling. Even with the proper and working ECM, I've see a 3.1/3100 have 6 bad injectors. If the resistance is in the injectors is off they won't work. Who knows maybe someone change the injectors and put the wrong type in (peak and hold instead of high resstance ones or whatever). Anyway based on what you've said you need to look into the injector wiring and see that they are being cycled on and off, it's the only thing it could b e. .
It was the injectors. Being it sat for 2-3 years it does not surprise me. Few were very low resistance and a couple seem to be stuck wide open. Installed the ones from the donor engine and fired right up. Runs extremely well.
Just need to disassemble the alternator now to see why the charging post is loose. Been driving it the last few days now.
Thanks for all the help on this one!!
