I have a 1988 2.8 MFI and recently the fuel rail pressure goes to 0 psi overnight??
Is there a one way valve or a check valve that could be faulty and not holding the pressure??
Also I'm getting engine code 54 and I have changed to a new fuel pump relay and also my oil pressure switch is only one terminal so it does not power the fuel pump when cranking.
someone said it could be my fuel pump is starting to die.
