stumbling beretta
  • stumbling beretta
    I'm working on a 95 Beretta with a 3400 and 282 swapped in to it. The problem I'm having is when its warm and traveling at descent speed it stumbles like its out of fuel when I try to accelerate, it goes away if i back off the throttle to a cruising speed. I have only heard of fuel pumps working or not working never heard one hiccupping before. I haven't checked the pressure yet I'm trying get my hands on gauge. also if the regulator is bad will the one from the 3400 fit in a small port 3100 fuel rail? I forgot to mention this is not swapping problem we have been driving the car around for about a year with this set up, just this problem has me baffled
    68 El camino 454 speed muncie 3.90 posi 12 bolt,
    80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
    60 Impala 2 door hardtop L79-327 T56 4.11 posi.
    83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
    91 Z34 now has a hm284. and belly pan in the works
    not sure what to tell you on your stumbling problem but i do know that the fpr from a 00+ 3400 will NOT work with a small port, at least it didnt with mine. i couldnt get over 3k with the 00+ fpr in mine.
      I found out that the 3400 fpr wouldn't work the day after I posted that, I finally found it hidden in my garage but thanks any ways 1meanz.
      It has appeared to be a mix of many things, the pressure was low and slow to react, so I replaced the pump and filter that fixed that problem. The cooling fan wouldn't come on with out using the A/C, I replace the relay and the temp sensor. I know the works when I turn on the A/C the fan comes on immediately. I still using the Beretta 2 wire temp sensor so I don't know exactly what the temp in at, but i can tell when the thermostat is opening. I wanting to do the 3 temp sensor when I replaced it but i didn't have a pigtail to wire in.
