i have a 95 monte, 3100. at normal cruising speeds it seems to either missfire, hestitate, sputter. if i kick it into passing gear...its still there, and if i stand on it...seems to make a popping noise...like its coughing. i ran dianostics on it... no codes have been set. when it's in park or neutral it seems to rev up fine. it has 166000 on it, the fuel pump and filter replaced at 156,000. don't know where to start since no codes have been set. i have a dodge diesel...that when the convertor is at that lock, unlock stage...it shutters some...what this monte feels like...but it doesn't seem to come out of it...like my truck. it has also had one coil replaced at about the 150,000 mi mark, heads redone at chev dealer,and the felpro gasket put in for intake at 135,000. any help would be greatly aprreciated!! thanks!
95 monte 3100-help
i'm not sure on the trans part...i'll do that tonite...i have to pull it into my shop, creamed a deer this morning!! hopefully i can get it driveable tonight. thanks for they help. what do you suggest for injector cleaner, i've used valvoline syntec in a chrysler concord that has injectors that gum up during the winter...and it seems to work fine on that motor. thanks again.
