Car is a 1995 Beretta Z26. 3400 with 3500 top end, 5 speed swapped running OBDII engine harness, and turbocharged on top of it.
Finally got everything back together (or so I thought). Now it's acting like it has a dead battery or a short somewhere. Whenever I try to turn the car over I just get a loud CLICK from the starter solenoid, but it doesnt turn over the engine. It seems like it's draining my power somewhere.
I've tried a known good battery. Tried a replacement starter. Same results.
I have the battery relocated into the trunk and as far as I know there's no issues with my ground or the power cable. Ran it identical to my last vehicle and it worked fine. Ground is grounded to the rear seatbelt bolt, power is run to the front, through the firewall and connected to the starter. The power cable connector IS slightly large on the starter, but I dont think it's touching the starter housing. Would that cause this issue anyway?
Starter wiring looks to be correct. Small ground to the little terminal, everything else to the large terminal. Tranny grounds are good. Everything seems to be hooked up as far as I can see.
Im stumped. Im thinking maybe I missed a connector under the dash, but I cant think of what it could be that would give me these symptoms.
Oh, and I thought it might have been the starter binding with the flywheel so I tried shimming it also, and it didnt work.
My brain is fried. Literally. I've been working on this thing non-stop for a year. I need a fresh outlook.
Any ideas or possibilities would be GREATLY appreciated.
